Photobucket How do you resize ?
   / Photobucket How do you resize ? #1
LBrown59
Super Star Member
First organized permanent settlement in the northw
2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
How do you use the resize feature on photo bucket?
Every picture I post on here turns out to big like this one did.
What am I doing wrong?
How do I fix it?
   / Photobucket How do you resize ? #2
Do you want to post clickable thumbnails, so when the reader clicks on the little thumbnail it expands open?
If so,
Once the photos are uploaded in your Photobucket, they will all appear as thumbnails on your screen. Below each photo is a square box with the name of the photo and also 4 types of formats, but disregard those.
What you want to do is check that box by the photo name by clicking on the box. You can check more than one photo at a time if you want. It will highlight the photo(s) and puts a red border around it.
After checking the box(s), scroll all the way down to the bottom of the page. There is an option to select/unselect all and also 3 rectangles below that.
You want to click on the one that says "Generate HTML and IMG code".
Click on it and another screen pops up with 5 more rectangles.
You want the 3rd rectangle down that says "IMG clickable thumbnails for message boards - recommended".
Highlight all that is in the box and Right mouseclick on it to copy it.
Then open up the TBN browser and "paste" the information into the reply with another right mouse click.
When you "Pre-view" your reply, you should see a clickable thumbnail in it along with your written post. That is why I don't use the "quick reply" so I can check my spelling and also my photos.
Click on the preview thumbnail and it should open up. If good, post it.
It should look like this.
   / Photobucket How do you resize ? #3
Hey 3RRL! It's been so long since I had posted any photos that I had forgotten how to do the Photobucket clickable thumbnail thing! I'm glad I came across this thread!
   / Photobucket How do you resize ? #5
If you look just above your phot there is a block tht says edit after that you can do all sorts of things including resize. 640 x426 works best.
   / Photobucket How do you resize ? #6
Just trying 3RRLs suggestion
And guess what it works! Thanks 3RRL
   / Photobucket How do you resize ? #7
Hey, that's great!
Now, if you want to make your photos look cool in a row instead of up and down like that, do this:
Go to the end of each photo URL and hit "delete". That will make the next one go behind the first one. Then press the "space" bar to put a space between them for each photo you want on the same row, so they come out like this.
2025 SF60 60in Hydraulic Forks and Frame Skid Steer Attachment (A56857)
2025 SF60 60in...
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
25ft Tag Trailer (A56435)
25ft Tag Trailer...
1977 Ford F-100 Super Cab Pickup Truck (A56858)
1977 Ford F-100...
Atlas Copco XAS90JD Portable Air Compressor (A57453)
Atlas Copco...
