Pertronix Distributor
   / Pertronix Distributor #1
retro7570
floyd,va.
4040 john deere
Just overhauled a MF to-35, can't get it to start, has a very erratic spark. Has a pertronix distributor that I don't Know much about. The magnetic ring on distributor has play in it, is this normal or my problem. Thanks
   / Pertronix Distributor #2
Ring should be firm over cam...If its loose the spacing between pickup unit and ring will vary causing it to be erratic... And don't connect up the leads backwards, electronic module goes POOF! if you do... And there is a set spacing electronic module need to be from ring...
Might find more about your distributor here.... All my knowledge comes from using Pertronix dist. in VW world...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
1673 (A54756)
1673 (A54756)
2015 Ford F-250 Knapheide Service Truck (A55788)
2015 Ford F-250...
2017 COTTRELL TRAILER (A55788)
2017 COTTRELL...
2007 FELLA SM350 3 PT DISC MOWER (A55301)
2007 FELLA SM350 3...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A54757)
UNUSED WOLVERINE...
