Personnel lift height
   / Personnel lift height #1
5030tinkerer
Iowa
Kubota GL3830/GL5030
Spencer's pole barn project and personnel lift has me majorly tempted to weld a personnel lift like his, but tall enough to enable easy access to a second story roof. The preliminary idea is to build pretty well exactly what he did deckwise (albeit 48x72), but have the second deck 9' off of the ground. Of course, each deck would have a 42" safety rail all around above it. The plan would be to build as follows:
Deck frames: 2" square tubing frame, supported every 9" OC using 1.5"x1.5" angle 1/8" thick
Deck itself: 5/8" #9 expanded metal
Corner posts: 2" square tubing frame
Sides and back for 42" above each deck: 5/8" #9 expanded metal
Like Spencer's I'd have a ladder built-in to get to the upper deck and side doors. Also like Spencer's, I'd use a removable bar (the 1/2" galvanized pipe idea seems good).
In addition, however, I'd cross brace the entire unit with something, perhaps using that same 1.5"x1.5" angle, 3/8" flat bar, or 1/2" bar stock (open to ideas here) welded up in the middle of each cross, with cross braces every 3'.
Am I crazy? I have a Kubota GL3830 HST with 723 loader rated at 1870 pounds lift at the pivet pin. Total lift height at the pin is about 8.5', so the intent would be to enable someone to step off of the second deck and onto the roof of an average two story home. /forums/images/graemlins/grin.gif
Would this be wildly unstable? /forums/images/graemlins/confused.gif
It has been privately suggested to me that I take one size larger tubing for the corners of the upper deck itself and weld short sections vertically to the 2" square tubing frame. This would enable the upper deck to slide over the 2" vertical corner posts. If 3/4" holes were drilled through the corner uprights at, say, 3', 6', and 9' heights (with corresponding 3/4" holes drilled through the vertical deck tubing), this would allow the placement of a pin through the holes and not always have to have the deck that I would be standing on so far from the pivet pin of the FEL. I'd have to come up with a new way to brace the corners if I did this, however.
Any comments on that idea or anything else here?
Still wondering if I am asking for trouble.
   / Personnel lift height #3
Do you have the link for the one your modeling after? I'd like to see it too.
A picture of Spencer's completed project can be seen here. The thread discussing the project is here. It's pretty cool.
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
John Deere 6120E (A50323)
John Deere 6120E...
2010 JOHN DEERE 648H SKIDDER (A51246)
2010 JOHN DEERE...
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2016 Freightliner 114SD Tandem Axle Dump Truck, VIN # 1FVHG3DV7GHHL8161 (A51572)
2016 Freightliner...
2018 Bobcat T-450 Skidsteer (A51573)
2018 Bobcat T-450...
