Permethrin mix for dogs
   / Permethrin mix for dogs #1
Western
Super Member
Wise county Texas
Kioti DK 35 now
I need the TBN brain trust. I have some Permethrin 10%.
My wife had made a mixture of almost 50/50 and put it on the dogs (large breed) last summer, one of them showed a reaction to it and I;m sure it was because of the solution ratio.
I had read a thread on here several years ago (cant find it now) where one of you dog breeders had a formula ratio for spraying/dipping/rubbing on dogs for ticks and fleas.???
Anyone have a "safe" ratio??
   / Permethrin mix for dogs #2
I suggest you call your veterinarian. He/she should be able to answer any questions.
   / Permethrin mix for dogs #3
You can find all kinds of info by using google.
Just be careful, Permethrin is deadly for cats!!! I found this information while looking for insecticide for fleas.
   / Permethrin mix for dogs #5
I'm going to ask someone with hunting dogs tomorrow.
I dont know about the vets up there, but most vets in my area are either busy or out on a herd check. If you dont have a relationship with one, you can also wait forever for a return call.
Google is the 1st thing I do, hard to beat trusted recommendations from reputable TBN members vs a Google "hit", but that is just my opinion. I do use Google like everyone else, but for "general" researching.
I was able to find the manufactures label online and think I have what I need (bottle lost the fold over label)
   / Permethrin mix for dogs #7
Use with caution on the dog that had the reaction. I have seen some dogs have an allergic reaction! Can truly make the K-9 ill also to pass on some information given to me years ago, keep small children away from the dogs after applied.
Sent from my iPad using TractorByNet
That is a concern, I 'm sure the solution she previously used was WAY too strong. !st thing I'm going to do is dust them with Diatomaceous earth, works slower but I have had good luck with it in the past.
The solution I found on the label breaks down to 1oz permethrin to 1.6 gallons of water, if I use it I will try it even "thinner"
   / Permethrin mix for dogs #9
0.25% is the typical commercial dilution rate for use in the house but not on the pets. I sell a lot of flea products but none contain permethrin for use directly on the animal.
I did some searching and found a few bits of information:
Some hunting and hiking forums recommend a mix where the Permethrin is at a 0.15% strength for use on the dog.
This link has some interesting info but no dosages Permethrin for Dogs - VetInfo
The products sold that I could find for application directly to the dog (United States) dont seem to tell you the dosages online. I would suggest you go to a pet store and look at the label on a product they sell to see the dosage.
   / Permethrin mix for dogs #10
Western,
Years ago I was a K9 handler on the PD we used " DURANON" made by Colton products inc. Easton P.A. Yellow and brown can with green top. Couldn't believe I still had it, 20 + years old. No I'm not a hoarder just luck.
I went and checked my supply closet can said 0.50% Permethrin. 99.5% inert ingredients.
Spoke with a current handler and one of the old trainers they don't believe it is made any longer due to illness caused by Permethrin, don't know for sure hope this helps.
David
2017 Volkswagen Jetta Sedan (A50324)
2017 Volkswagen...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
1268 (A50490)
1268 (A50490)
2012 Ford F-150 Crew Cab Pickup Truck (A50323)
2012 Ford F-150...
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
