Permanent magnet alternator wiring
   / Permanent magnet alternator wiring #1
timbatrader
Pakihi New Zealand
YCT306S-S bulldozer Leyland 344 tractor, Mountain Raise MR926S wheel Loader, Hitachi 19U mini Excavator
I have replaced several generators and externally regulated alternator's on old tractors with modern two wire alternators simple one wire to the battery and second to the key switch via the charge light on the dash a neighbour has asked for help with his tractor which a standard car alternator will not fit but has got hold of an internally regulated permanent magnet alternator that will physically fit but it has four wires coming out. can anyone help as to how to wire this up ?
my guess being permanent magnet it will not need current from the key switch to excite coil does all it need the big single wire connected either before or after the key switch to the battery?
KOKUSAN DENKI: GP9905
ITEM DESCRIPTION: ALTERNATOR
UNIT TYPE: ISUZU
VOLTAGE: 12
AMPERAGE: 20
REGULATOR: INTERNAL
POLARITY: NEGATIVE
SPECIFICATIONS: PERMANENT MAGNET
NOTES: (1) THREADED & (1) UNTHREADED MOUNTING EAR
WEIGHT: 5.61 LBS / 2.55 KG
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2008 Nautica International RIB 24ft Cat Boat with T/A Boat Trailer (A50324)
2008 Nautica...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
