Perkins Oil Filter Housing Question
   / Perkins Oil Filter Housing Question #1
zslnk
Bronze Member
ON, Canada
MF 135
Hi,
I bought a new (old) MF135 and I'm changing the oil and something seems wrong in the housing. The filter just drops into the housing with no spring pressure to keep the filter up and against the big O-ring in the housing. My other MF is at the farm and I can't take it apart to verify. I believe this tractor has been running in 'bypass' for an unknown period of time. Can someone please confirm that the spring should go under the plate with the Oring to keep the filter up and force oil to go through the filter?
Thanks,
   / Perkins Oil Filter Housing Question #3
Or ...get a filter atachment from a MF 240 and change to a screw-on filter
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
1999 Blaw-Knox PF 161 Paver (A52384)
1999 Blaw-Knox PF...
2008 Nissan Sentra Sedan (A51694)
2008 Nissan Sentra...
International Cab and Chassis (A51692)
International Cab...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
