Perkins Fuel Problem
   / Perkins Fuel Problem #1
Believer
Have a 4 cyl Perkins on a chipper. Can't get it to run. Looks like a fuel problem.
To rule out some issues I'm running an electric fuel pump straight to the injector pump. I cracked all the lines at the injectors. With the electric pump running alone, I get alot of fuel out of one line but not much out of the others. If I crank the engine, I get some squirts out of all of them.
It will almost get going but if I let off the starter it will slow down and die. The only thing I can think of is the injection pump. Any advice? Thanks.
   / Perkins Fuel Problem #2
I had the same problem on mine, and if I remember right, you had to bleed the injection pump from two different places or it would not start. I would just Google, "bleeding a perkins diesel".
Rick
   / Perkins Fuel Problem #3
If u narrow it down to the ip, I’m available to have a look at it..
U can contact me thru here by clicking on my screen name..
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
UNUSED Jack Lift 5/10 Ton (A53117)
UNUSED Jack Lift...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
12ft T/A Park Dump Trailer (A52377)
12ft T/A Park Dump...
Utility Trailer (A52377)
Utility Trailer...
