Perkins 4.108 no start
   / Perkins 4.108 no start #1
butchfig8
Have a perkins 4 cyl basket case put together.
Spring loaded lever on inj pump is throttle correct ??
Other lever on inj pump is Shut off lever, Turned which way to shut off ??
Getting fuel up to inj, Can get :confused:motor to raddle a little bit with start fluid, but thats about all.
   / Perkins 4.108 no start #2
G'day butch and welcome to TBN the shut off lever should make a huge difference to the amount of fuel coming up to the inj have you got the timing right when you assembled ?
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
