MoKelly
Super Member
- Joined
- Oct 30, 2009
- Messages
- 5,870
- Tractor
- Bobcat CT235, Bad Boy z-turn, Suzuki Vinson 500 and F-150
I want to try to build a pergula in the back yard area of my house. I have never done anything like this myself but see what the folks on here can do so I want to try to do it myself. It's not like we will live in it so I figure what the heck ... lets give it a try. I have my 16 year old son available to help me with the harder work. Other than that, I will do this on my own.
So, I am in the planning stages and here is my plan:
--- The area available is pretty flat and is mulched. So, no need to do any major landscapping work. We plan to leave the area mulched with some planters and pavers.
--- I would like the pergula to measure 12 feet wide and 16 feet long. The beams will span the 12 foot section and the rafters will span the 16 foot section. I plan to have 2 foot overhangs on the rafter side ... so ... the rafters will span 11 feet 1 inch. I plan to have 1-1/2 foot overhang on the beams so they will span 8 feet 1 inch.
--- I will use 4 - 6x6x12 posts buried 4 feet (with 8 feet above ground) with concrete. I will wrap and treat the portion of the post in the ground. I will use pressure treated wood which we will eventually paint white.
--- The beams will be 4 - 2x8x12 boards sandwiched and bolted to the posts.
--- The rafters will be 12 - 2x6x16 boards screwed into the beams every foot. I sort of want to notch each rafter into the beam with a 2 inch notch in the rafter. Not sure if this helps the structure stability or not, but I think it looks a little better.
--- Maybe, depending upon how it looks at this point, we wol use 2x2's across the rafters. That is yet to be determined and, at least to me, isn't a decision we need quite yet.
Also, my wife is toying with the idea of a porch type swing on teh 12 foot side of the pergula. I am niot sure what additional strength needs to be built (if any) to accomodate that desire.
So, that is my plan. Please provide whatever comments you think I need to be successful.
Thanks much.
MoKelly
Thanks much.
MoKelly
