We have a new concrete patio and hired a contractor to build a freestanding pergola on a portion of it- we've had other projects this spring and felt this was best left to a professional. The pergola is 4X4 redwood posts, with two 4X6 beams Simpson tied to the posts and 2X6 purlins (rafters?). The posts are attached with a Simpson post bracket that has been attached to the patio with tap-cons.
The problem is the pergola racks/wobbles a lot and is not stable enough at all. The contractors solution is to attach large T-straps from two or three of the 2X6 purlins over the gutter to the roof of the house bolted into the sub-fascia thru the roof shingles. I'm not thrilled with this plan, and my wife hates it. It was supposed to be freestanding and not tied to the house. Does anyone have advice on stabilizing this structure? We were thinking of adding a longer knee brace in addition to the one all ready there (so there would be two parallel knee braces). Perhaps hanging 4X4 beams in between and at 90 degrees to the current beams with knee braces. As you can see from the pictures, it has temporary bracing to keep the thing from coming down while we figure this out.
