handirifle
Veteran Member
Well, we finished building the house in 2010. A few months later I built my workshop, a 24x30x10ft stick built. At the same time the foundation for the shop was poured, I had a slab poured for a spa and pergola. I included post supports for 6x6 set in the concrete, when I poured this slab. I dug footings under each place a post support would set. So there is sat. I put the spa on it a couple months later, after running elec to the location. I pulled 80 amps, 50 for the spa and 30 for whatever else we might want to add.
This has been like this for about 2.5yrs now and we finally accumulated the funds to complete the project.
Sorry no TRUE before pic, only when I first started. This as close to BEFORE as I can get. Just eliminate the post, and there you have it.
Backtracking a bit is the 20ft flatbed loaded with most of the lumber (more on that later). Not sure of your prices, but that is $1300 worth of lumber. Sure doesn't look like a lot of wood.
See the first pic for the very beginning of the build.
There are 7, 6x6 posts. I left the front open and clear for a wide open entrance.
Here are the 4 corner posts, braced to hold plumb.
There is also 2 of the 8 2x10's I used as headers.
