Rotary Cutter PERFECT Brand Mowers
   / PERFECT Brand Mowers #1
LiveRoll
Irricana Alberta
Kubota M108 FWA loader, 2014 Kubota M7060,Kubota MX 5100, Ford 1500, Kubota Bx25 , Kubota RTV900, Kubota ZD331 Zero turn mower.Kubota B1200 Grey to be restored.
I am currently looking at a Perfect Mower. 9' Model LB 275V. I am wondering if this would be an adequate mower. It has 3 rotary cutters with swinging blades, like a standard rotary rough cut. I currently have 2 72" rotary rough cuts, ( one JD MX 6 and a Land pride 72" as well as a JD 390 flail.
I would be interested to hear from anyone that has used or has one of these Perfect mowers, as to it's performance, and if it is designed to take on heavy growth or if it is basically limited to "pasture topping" . The nearest dealer is 10 hours away, and it looks as though the consumables ( belts, cutters ) may be more reasonably priced than changing out a set of cutters on my 390 flail which is around $ 1000.00
Thanks so much fella's!!
Cheers
Roger
   / PERFECT Brand Mowers #2
Hello Roger,
Did you get price from Clean Cutter and Flail Master for side slicer knives?
The JD knives would be very expensive.
The V belts are a common belt and you can buy them as Kevlar belts from
other retailers than the local green shop.
We used the JD25A my father had for everything and it never let us down.
   / PERFECT Brand Mowers #3
Looks to me like just something for topping. Dont look like it would take on too much heavy growth. Watch the video. Not really impressive IMO. Its basically a 9' Finish mower
Yes, I watched the video a couple of times, and I'm afraid I have to agree with you, and at 9 ft wide and riding on skids with a narrow roller across the back it would not do too well hanging over the ditch-bank mowing road-sides, even on undulating terrain I can see it missing areas due to it's width. perhaps a sod farm or a orchard. I think a lot of their products are basically designed for orchard or speciality work. I do find their blade configuration interesting.
I really appreciate your inputs!!( basically helping me to talk myself out of buying it and perhaps making a mistake!!)
Cheers
Roger
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A53472)
UNVERFERTH 330 8...
2016 GMC Sierra Pickup Truck, VIN # 1GTN1LEC5GZ901362 (A51572)
2016 GMC Sierra...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
