crazyal
Super Member
There was an auction close by that had me a little interested. In it they had a 16' equipment trailer listed as "in poor condition". While the rust wasn't as bad as they made it out to be when I got there I found that it had surge brakes and mobile home style axles. They weren't from a mobile home (it's a factory made trailer) but the tires aren't easy to get unless you want to go to a mobile home dealer and go that route. I couldn't find manufacture's name plate but would guess it was rated for 10,000 lbs. At some point someone cut both of the main rails to add stake pockets which then needed to be reinforced because the steel was cracking. Also one of the two rails going to the hitch was bent.
Unless the drums were designed for both hydraulic and electric brakes I figure that it was going to cost at least $1000 to convert it (brakes, wheels, and tires). That was assuming that the master cylinder could be rebuilt (if it was converted to disk brakes) as it was at least 30 years old and the axle stubs were a common dimension. It's not that surge brakes are terrible but they are expensive to repair and I've never felt like the drum style ones had great stopping power.
For the right price I would have bought it but it sold for almost $1400. With not too much searching you can find a newer 10k trailer for less than $2k around here with electric brakes, standard wheels, and in better shape. Am I wrong? Would you have paid that much for it?
