Penetrating Oils
   / Penetrating Oils #1
Grommit
I know this is not Chinese tractor specific but you guys helped me with a problem I had last year with my Siromer and I wanted to share this with you as I have posted nothing since. The following was recently posted on a motorcycle forum I look in on and compares penetrating oils on identical test pieces - I think it was taken from a US magazine that claims the tests were based on "lab" type material conditions.
Anyway, I have just changed all 48 flails on my flail mower in the space of about 1 hour, a job that last time took closer to 3, using WD40. I mixed the acetone and ATF 50/50, mixed it into a mayo type liquid and painted it on to the bolts with an old paint brush, few hours to let it sink in and the bolts come off no problem :D
It really does work and is a great home brew farm fix to an old problem. Give it a go - hopefully you can get Acetone, it's sold in supermarkets here in France:thumbsup:
Penetrating oil ..... Average load
None ..................... 516 pounds
WD-40 .................. 238 pounds
PB Blaster ..............214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............ 106 pounds
ATF-Acetone mix... 53 pounds
The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic
transmission fluid and acetone.
   / Penetrating Oils
Sorry just seen its already been posted :ashamed:
But at least I can confirm it does work:eek:
   / Penetrating Oils #4
Grommit, I'll give it a try. Never heard of it before. Thanks for posting it.
   / Penetrating Oils #5
As discussed in a previous thread on the ATF/Acetone solvent...the biggest problem is containing it..you really need a sealed metal can or glass jar...I use a pump type oil can and fill it from a jar as the acetone evaporates from the oiler...
   / Penetrating Oils #6
The mix melted my first container. I put mine in a new oil can. It ate all the seals out. It still pumps, but will leak all over when I use it. I'll put up with it, it works so good. I still have PB Blaster on hand for the easy things.
   / Penetrating Oils #7
Acetone is a tough cookie to contain. I've seen metal containers that have never been opened become lighter and lighter until they were enpty.
   / Penetrating Oils #8
thanks for the tip :thumbsup:
Anyone know where can I buy acetone in the states?
Year: 2015 Make: Peterbilt Model: 320 Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2015 Make...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
