Peeling back Sod
   / Peeling back Sod #1
johnk
Elite Member
western NY
Kubota GST Grand L3130 w/ 723 loader, Ags
My Son-InLaw wanted to know if I could peel off some sod in an area of roughly 15X40 feet. It would be no problem to do it but he wanted to reuse it after he raises the area with 6 to 8 inches of topsoil. Whats the best way to attack this. Plain bucket edge, bucket w/toothbar, boxscraper or rent a sod buster. If I remember a few years ago by accident I had my scraper blade down with the top link lengtheded it it rolled the sod nicely. Only problem is my backblade isn't here it's at my cabin.. Suggestions????
   / Peeling back Sod #2
If you really want to reuse it I would rent the cutter. It will be very tough to skim it off in a reusable manner.
   / Peeling back Sod #3
I relocated some for my neighbor a few years ago. Centipede grass that had spread into a field and made pretty good sod. I used the regular front loader bucket and it rolled up right well. I could cut pieces 5 1/2 feet wide and three or four feet long. Certainly well enough for what he was doing, not in a hurry for perfect. But I can know that a real sod cutter would have gotten a more consistant thickness.
My loader bucket is better suited for that than a lot I've seen, too. A sharp lip and the back of the bucket is half-moon round, no angles.
Wm
An edit - I hadn't mentioned this before, but if you right click on the image by my name and then click "View Image" it will show you a full size view of the bucket. Everybody else's shows the image the same size as what you see on this page. Wonder what I did wrong? /forums/images/graemlins/smirk.gif
ITEM LOCATION (A53084)
2014 International DuraStar 4300 4x4 Terex BT3063 63FT 15 Ton Crane Truck (A51691)
2014 International...
Kohler Transfer Switch & Generac 200A Transfer Swi (A53117)
Kohler Transfer...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
