Pea Sheller
   / Pea Sheller #1
Jbbies
Bronze Member
Colorado
Kubota B2620
Anyone ever make or have plans for a homebuilt pea sheller? I have seen some on the net with a big drum that turns inside a frame... but cant really see exactly how its made.
Thanks Brandon
   / Pea Sheller #2
We take our peas to a man who has a sheller. The drum is made of oak with the frame inside of the screen so the frame beats up the pea shells as it turns, there is a beater that turns about twice as fast as the drum and is just oak 1x2s that extend out from the shaft on small angle(think the reel on a small grain header on a combine) the beater boards are about 2" away from the frame work of the screen. One other thing this sheller has a wide belt the width of the sheller that sits on a slant and runs with the top of the belt going up. peas roll down and hull pieces go up and out the back. I know what I said here is not very clear but i hope it helps, if you ask a direct question about a part ect i will try to answer if no one else can do better. Ed
   / Pea Sheller #3
Thanks Brandon
http://davesgarden.com/files/bean_sheller/
Here are some fairly detailed plans. I have no experience with the design. Just trying to help you out.
Hope this is what you were looking for.
   / Pea Sheller #4
I have two different ones, I like the mr. pea one better you can motorize it with a drill. I got lucky and found it on ebay for a low price.
   / Pea Sheller
Ed the one you describe is what I think I have been seeing... I would love to make one just need to figure out some plans.
   / Pea Sheller
Depmandog... that is exactly what im looking for... now if I can fully read them and find some time this winter I will build one.
thanks
   / Pea Sheller #7
thanks
Glad that website was what you were looking for!
Remember, start a thread showing us the build - lots of pictures too!!
   / Pea Sheller #8
Jbbies That is close to the one I use, the main difference is the lack of a wide belt running under the thrashing drum. Out of three 5 gal buckets of peas in the hull we put all of the bits of hull in the bottom of a tea cup. That belt really makes a difference.
2008 HEIL PNEUMATIC TRAILER (A45333)
2008 HEIL...
2019 Chevrolet Tahoe SUV (A42744)
2019 Chevrolet...
2019 GARDENER DENVER 2500HP QUINTUPLEX FRAC PUMP (A45333)
2019 GARDENER...
2025 Spirit Electric Scooter (A42744)
2025 Spirit...
2015 TYTANK PNEUMATIC DRY BULK TANDEM AXLE TRAILER (A43004)
2015 TYTANK...
2008 WELLS CARGO 16’ T/A ENCLOSED TRAILER (A45046)
2008 WELLS CARGO...
