Paumco Quick Spade in Canada
   / Paumco Quick Spade in Canada #1
mangler
Ontario, Canada
Sears G5500, Kioti CK2610
Looking to buy this spade in Canada.
Quick Spade | Paumco Products, Inc
I found some "equivalent" products, but the prices are way too high. Does anyone know if Paumco has a dealer in Canada, bonus if they are in Ontario? I'd accept a comparable product, at a comparable price also.
I have a lot of Autumn Olives to uproot, and that spade would likely work well on my pallet forks.
   / Paumco Quick Spade in Canada #2
Id recommend buying a dedicated spade bucket if you want to have your forks remain parallel. Forks are made to lift, not push and dig.
Mikester,
I bought the 4000lbs heavy duty forks for this very reason. When they are jammed to gether I think they would be quite strong, but that is a good point.
Has anyone permanently bent their forks with a slip on bucket spade? if so what were the circumstances (tractor, fork capacity and length, soil type, specific project/extraction)?
   / Paumco Quick Spade in Canada #4
Any comments on paumco vs titan vs bucket solutions? Getting ready to buy a spade
   / Paumco Quick Spade in Canada #5
Bucket spades vary considerably in weight.
Buy Bucket Spade weight proportional to tractor weight. Light for up to 2,000 pounds bare tractor weight. Medium for 2,500 to 3,500 pound bare tractor weight. Heavy for 4,000 to 5,000 pounds bare tractor weight.
If you buy a heavy spade for a light tractor you will have little spade "payload". The length of a heavy spade works against you on a light tractor.
   / Paumco Quick Spade in Canada #6
Bent forks are common at the scrap yard.
Use a combo spade with forks on the Kubota B26 for olive and privet shallow rooted invasives. Would have to be careful with a bigger tractor.
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2012 SOUTHERN VAC  130 BBL STEEL VACUUM TANK TRAILER (A52472)
2012 SOUTHERN VAC...
2015 John Deere Z950M 70in Zero Turn Mower (A51691)
2015 John Deere...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
