Pat's Easy Change pats with l3800
   / pats with l3800 #1
dwight jr
southern middle tn
kubota l3800-m9000-jd4430
has anyone used pats easy change on a kubotal3800-how do you like them? thanks
   / pats with l3800 #2
I have them on mine. I absolutely love them. They do extend the implement slightly, so the range of the original top link becomes limited when using them so I bought another slightly longer top link, which is really a good change to make anyway since it adjusts so much more easily than the original top link. Changing implements is a breeze for me. I simply back up to the implement, and push a little until both Pats hooks are even with it, lift the 3PH until it clicks on both sides (kind of guides itself in), then hop off and hook up the top link which is easily adjustable and the PTO if a PTO implement. Very easy one person changing rarely takes me more than a couple minutes to change between anything. I have adjusted all implements to the same width to match the one that is not adjustable so all 3 are very easy to deal with.
I had previously had to help friends hook up on their tractors without Pat's and would never go back to fiddling with it like they do. I recommend Pat's or a quick hitch system to anyone and everyone.
   / pats with l3800 #3
I have the Tractor supply version on my L3700. It works well and I have the same issue with the top link at TSs post above. Just haven't bought a longer top link as of yet. They work well.
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2015 FREIGHTLINER...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
IH 1066 Tractor (A50514)
IH 1066 Tractor...
UNUSED TOPCAT SSSG72 HYD QUICK ATTACH GRADER BLADE (A51244)
UNUSED TOPCAT...
