Pat's Easy Change Pat's EZ Hitch and Top Link Length
   / Pat's EZ Hitch and Top Link Length #1
acohen100
Southern Vermont
Kubota BX24
Just installed the EZ Hitch on my BX24 and it seems wonderful. The only issues are that it does move the implement back about 3-4" and so there is less lift capacity...so far not a major issue. But also now my top link seems a bit short for some attachments. Is there an easy solution for this? Can I just go out and buy a longer top link? Is there an adapter I can get to lengthen it?
   / Pat's EZ Hitch and Top Link Length #2
I went to TSC and acquired a longer toplink to go with mine.
   / Pat's EZ Hitch and Top Link Length #3
You can get a longer top link.
Some make adapters that lengthen things.
Others take this as an opportunity to work up a need for a hydraulic top link:D
Me, I have a hydraulic top link... really wonderful thing to have...
What's the advantage to a hydraulic top link? Increased lifting capacity?
   / Pat's EZ Hitch and Top Link Length #5
You can adjust the length much faster plus it makes tilting some implements like a box blade much easier. And it makes a very nice project if you're new to hydraulics ;)
Search for Top-N-Tilt or TNT for some more information.
   / Pat's EZ Hitch and Top Link Length #6
Not having to get off of the tractor. ;) :D
   / Pat's EZ Hitch and Top Link Length #7
http://www.tractorbynet.com/forums/attachments/31818-pats-easy-change-system-order.html
Or exclusively here ==> http://www.tractorbynet.com/forums/1195785-post143.html
That's pretty nice but my tractor does not have a multi-pin 3PH receiver like your tractor does so that wouldn't work for me. I just have a single pin receiver. Guess I should just buy a new top link.
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51242)
SET OF SKID STEER...
150 GALLON FUEL TANK (A51244)
150 GALLON FUEL...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2023 CATERPILLAR 299D3XE SKID STEER (A51242)
2023 CATERPILLAR...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
