Pat's Easy Change Pats easy change?
   / Pats easy change? #2
I think no.
Color is wrong, most I have seen are gray. No piece to hold the latch open and no hold down holes for the lock bolts. Look like a knock off version
now several picts down, is the same photos without the "pats" label in the description.
   / Pats easy change? #3
For CERTAIN it is NOT the original Pats.
It sits on TOP of the arm while Pats extends along the arm of the 3ph.
   / Pats easy change? #4
Does'nt look like the one that I got from Pat's, not saying that it is'nt either a newer or older design but it's not like mine or several others in my area that has em.
   / Pats easy change? #5
No thats not a Pats. Its simular but not the real thing.
   / Pats easy change?
Just as I thought, if its too good of a deal, its a knock-off
CASE 6591 T/A PORTABLE POWER UNIT (A51243)
CASE 6591 T/A...
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
2014 Ag Spray Schaben Sidedresser (A52128)
2014 Ag Spray...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A52128)
Hay Van FL-95 Bale...
80in HD Tooth Bucket with Side Cutters (A52128)
80in HD Tooth...
