Pat's Easy Change Pat's Easy Change System
   / Pat's Easy Change System #1
Mike120
TX
First of all, this is not a criticism of Pat's system. I've got a quick hitch on my little tractor which is fine for small stuff, but Pat's system with a hydraulic top link is the best thing I've found for Cat 2 implements. That is?.until you try to take them off.
The tractor they are on gets about 700 hrs a year with numerous implement changes daily. The end hooks get beat up and I'm not the best about keeping them tight. First the springs busted and I replaced them (Pat sent them for free) then the latch handles broke off. I got tired of manually unlatching stuff and I decided to replace them so I bought another set.
The fun began when I tried to take off the old ones, Naturally all of the adjusting bolts were rusted and frozen. A few minutes with a metal blade in my sawzall took care of them. The problem was that the 1" pin going through the ball-end was seriously frozen. I doused it with PB Blaster and beat on it for a while with no results. I finally prevailed with a combination of cutting torch, 4" grinder, and sledgehammer. I would rather not repeat the experience when it comes time to replace this set. I'll also try to be nicer to them as well.
I'm considering grinding the new 1" pin down slightly so it doesn't fit as tightly in the ball. I've also thought about putting some grooves on the pin so that I can squirt some WD-40 on it once in a while to keep it from seizing up. Anybody got any better suggestions??
I need to put the new ones on pretty quick. I hooked up a carryall to the tractor last night and without the hooks it was a real pain.
   / Pat's Easy Change System #2
How in the world did you break the latch handles off?
   / Pat's Easy Change System #3
Don't know how Mike did it, but it's pretty common for me to inadvertently stand on mine and bend them.:confused:
Mike, you can consider adding a grease nipple to the pins like this. These are not for Pat's, but shows how you could install a grease fitting into a pin for lubrication.
   / Pat's Easy Change System #4
I would think a good greasing with a Moly grease or good antisieze would make them come out later fairly easily. With the Pat's in and mounted there should be very little, if any movement to displace the grease, and the Pat's themselves would act somewhat as a sheild.
Thanks guys!
Breaking off the latch handles is easy....just run without springs for a while and they'll break off. Even with Cat 2 pins or sleeves on Cat 1 pins, there is some play. Ground engagement implements bounce around and after a while without springs the latches will just diaappear. I was using baling twine to keep them from opening, but it didn't keep them from vibrating. I guess it weakened the weld. I'll be better about keeping the springs in this new pair.
3RRL, that was one of my thoughts, but I doubt that I would do anything as neat as the pins in your pictures. Having reflected on the experience, my thoughts are that the paint on the pins is likely the cause of the sticking. I suspect that over time, the paint swells and combines with the rust to form a bond. I'm going to strip them and put a couple of grooves in the new ones, along with a liberal coating of grease. We'll see in a few years how successful it is. Hopefully I'll never have to replace them and I can just trade them in when I replace that tractor.
Pat has made a few minor changes in the new ones that I expect will make it easier to keep them tight. The springs look easier to replace as well.
   / Pat's Easy Change System #6
Mike120,
I would have replaced the latches. If you want call me and I can send them to you and you can maybe find someone that would like a deal on a used set. About a year ago we changed over to all stainless steel springs as opposed to the zinc plated. More expensive but seem to be holding up a lot better. About that time we changed the set screws to hex head bolts, seems to be a lot easier. We have recently changed how the spring attaches to the latch handle and it seems to work a lot better. We keep trying to listen to you guy's suggestions and improve. As for the main pin rusting, that is a first for me. But I will listen to any suggestions to help.
   / Pat's Easy Change System #7
Neversieze is your best friend........
I got my set of used Pat's (look new!) the other day. I haven't got a chance to completely put them on, yet. Pat, you say you switched to a hex head bolt in place of the allen set screws?
   / Pat's Easy Change System #8
I sure hope you've redesigned the cotter pin attachment. Mine broke years ago and I have just never taken them off to replace the cotter pins.
   / Pat's Easy Change System #9
Mine have been so abused I'll bet I've replace broken bolts several times now.
I love them so much though, I'm considering just welding on to the drag links.
I will never take them off anyway.
   / Pat's Easy Change System #10
Yes, we changed the set screws about a year ago to hex head bolts. We figured more people would have a wrench to fit than hunt an allen wrench. We did change the cotter keys to stainless steel about two years ago. Once again, more expensive but a lot more durable. Contact me and I would be happy to send you the cotter key. If you use a large pair of channel locks to squeeze from the top and bottom the cotter key goes in pretty easy.
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2013 Chevy Silverado 2500 HD (A52128)
2013 Chevy...
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
