Pat's easy change on 5740
   / Pat's easy change on 5740 #1
Ron Henderson
Well, this is the first time I have mounted my 7' bush hog to my tractor without hurting my back.
Pat's easy change system makes hook up a breeze!!
The install was very easy, took approx 30 minutes.
All the parts appear to be well built.
If you are going to buy these for a 5740 or like Montana I suggest you call and order from Pat's direct.
This is because the lift arms on the 5740 are quite large compared to some of the other makes.
They make them a little larger for the Montana and have them in stock.
They will give you the TBN price.
I purchased the cat 2 kit and found the instructions easy to follow and all the parts were actually there.
Ron
   / Pat's easy change on 5740 #2
I appreciate the good info but it's takes me less time to connect and disconnect my 8 foot brushhog type mower on my 5740C than it ever did on my Kubota. Never takes me over 20 minutes and is as easy as it gets without anything but me, my 5740C, and the mower.
   / Pat's easy change on 5740 #3
I think he meant that it took 30 minutes to install the Pat's Easy Change to his lower links. Once they're installed, you just hook under the implement's lower links to grab it.
LMC LOT NUMBER 269 (A53084)
LMC LOT NUMBER 269...
2023 UNVERFERTH 632 LOT NUMBER 179 (A53084)
2023 UNVERFERTH...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2014 PETERBILT 579 SLEEPER (A52576)
2014 PETERBILT 579...
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
