Pats' Easy Change and 3 pt clearance
   / Pats' Easy Change and 3 pt clearance #1
SI2305
I don't want sound like an advertisement, but I have to relate an experience of mine following the addition of a Pat's Easy Change.
Like many others who have owned a 2305 (and other sub-compacts in general), I have been VERY pleased by its performance, with my main concern being its clearance. I did have some difficulty with my LX4 and Grader blade. The former I could reset to carry higher and the latter I had to physically modify in order to carry without scraping ground at even small hills.
Like many, I had wished that the top link were shorter to really pull up the read implement, but I got the perfect equivilant when I added the Pat's Easy Change. The new links add about 2 inches in length to the lower bars, but this short distance make a dramatic difference in how much higher I can get rear implements off the ground. When I first hooked up my grader blade and raised it to the max, I thought something had broken--it had never gotten so far off the ground before. Now I can traverse my front ditch without shaving off a slice of grass. The LX4 gets really high off the ground and can clear any obstacle. In fact, I actually had to LENGTHEN the top link--something I never considered in the past.
I don't know it other easy chang systems have this added benifit for sub-compacts, but Pat's surely does. Not only is it easier to change implements, but they fit better as well.
Happy Tractoring
SI2305
2005 JD2305, 200cx, LX4, 5' grader blade, ROPS lights, Pat's Easy Change
UNUSED LANDHERO LDH-T460 STAND ON SKID STEER (A54756)
UNUSED LANDHERO...
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A55301)
2006 Magnolia Dry...
JOHN DEERE 8345RT TWIN TRACK ROW CROP TRACTOR (A54756)
JOHN DEERE 8345RT...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
