Patio steps
   / Patio steps #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Looking for advice on how to make patio steps.
Scenario: French doors open to back patio which has been graded and is (without measuring) say 3 feet to the ground.
My anticipation (looking at currently available materials) is to lay some 8x16 blocks on the ground to make the base, or what will become the first step (from the grounds perspective). Make a rectangle maybe 6 feet wide by maybe 3 1/2 feet deep (just wild guesses again, without measuring). Concrete these together, lay another course on top of these that will be the second step. After I make maybe 3 layers, take some more concrete and pour into the web openings for strength & rigidity.
Once this skeleton is made, I can then use concrete and "glue" some flagstone, which will match the patio, onto the sides & top of blocks finishing it off.
Will this work?
Should I first pour a concrete base for the block to rest on or is the ground (clay) sufficient?
Richard
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2016 Kubota RTV-X900 4x4 Diesel Utility Cart (A51691)
2016 Kubota...
INMY Manual Landing Gear (A51692)
INMY Manual...
2025 Epic Electric Golf Cart (A51694)
2025 Epic Electric...
