Pasture renovation project...
   / Pasture renovation project... #1
dixiedrifter
Bout a month ago I decided to renovate a couple of my pastures... two of them have not been worked or limed in at least 15 years. It was starting to go primarly to broomsedge and weeds with a little bit of fescue in the spring time. The big first field's pH had gotten so low that fertilzing in the spring didn't do any good as it would all get "locked up"... the second smaller field across the road which I tested a couple years ago called for 2.5 tons of lime to bring the pH up to normal so thats what I'm hitting both fields with.
So, needless to say a good plowing and liming was in order. First step was to run over it with a disc mower set to "scalp" and then bale up as much grass possible (sorry no pics). Then, sit back and wait for it to rain to soften the ground up enough for it to be worked.
About two weeks after I got it cut it finally started raining off and on for about a week. The day after it finished raining and soaked in I tried running an 8' tufline disc with notched discs over the field to cut up the sod. That idea didn't work worth a dern... the disc would go maybe an inch or so deep and mostly wiggled back and forth... kinda like a squirrel on crystal meth playing in the road waiting to get run over by a car.
So I ended up using my spring tine cultivator and section harrow. Its a pretty sweet piece of machinery and works better than any disc as long as there is not enough residue to get caught up on the shanks. I welded a couple of angle iron brackets on the back and drilled a couple holes in them so I could use a quick link to attach the section harrow. When it comes time to move the section harrow it can easily be hooked back up and the harrow moved with the 3ph.
Man, the ground on the first field was HARD. The M9000 has 4WD and the back tires filled and it was all the old girl wanted in 4th gear with the cultivator about half way down in the ground. There were several occasions where my tractor started to get a little bit warm and I had to stop every couple rounds and let it cool back down... (didn't help that my radiator needed some cleaning either). When I went to take the spring tine cultivator off I noticed that Cat I pins were noticably BENT and the points needed to be flipped over. It took me 3 days of plowing and discing to finally get the field below looking as good as it is in the pic below. I think it done a pretty dern good job myself all things considered.
Now if I can just get the local fertilizer dealer to bring out a load of lime and get another rain on it, it'll be ready to plow, cultipack and plant in wheat for the winter. He has been dragging for the last two weeks, and when he tried to get to it earlier this week his spreader tore up on him. I'm giving him till the end of next week, and if it ain't limed I'm gonna call someone else... three weeks is BS!
In the spring I plan on having a neighbor combine the wheat in the spring leaving the spreaders off on the combine, bale up as much straw as possible, do another soil test an apply any more lime that it might need and sow in bermudagrass.
   / Pasture renovation project... #2
You done good!:D
What type of shovels on the cultivator?:D
   / Pasture renovation project... #3
Hey All,
Looks good! Don't know where your at but how late can you plant wheat? Weeds may be an issue at combining. Let us know how it goes.
-Ed-
Just a few pics to show how it looks... got my wheat planted, fertilized, and the ground limed.
These pics are a few weeks old, the wheat looks pretty thin IMO, but it has really greened up since then and the wheat is tillering out quite nicely.
The grain drill was definatly the ticket... although I think it was not quite putting the seed out at the rate that I wanted.
This pic was taken in the same spot as the first photo above.
These pics were taken in the second field, just on the opposite end:
   / Pasture renovation project... #5
you can tell you put alot into diskinf an leveling those fields up.your wheat looks like its growing good as well.insted of combining the wheat an baling the straw in june.why not bale the wheat for hay at the end of april or 1st of may.
I figure wheat will probably be running $6 or so a bushel in the spring... if it makes 30bu per acre thats $180 gross plus another $100 or so for the straw.
The other problem with cutting early is rain... usually it is raining like crazy during that time of the year here in TN... it wouldn't dry out in time.
   / Pasture renovation project... #7
Looks really nice. Are you seeing any deer out there eating your wheat?
Eddie
Well its lookin more and more like wheat, and yeah, the deer have been working on it. Got a couple nice young bucks running around that I usually see late of an evening... one 4 and one 6 pointer and a bunch of does.
So far its been a rather crappy year. 6+ inches of rain ahead of schedule... think part of my fertilizer I applied a couple weeks ago washed away.
I think the stand could be about 10-15% thicker and it would be perfect.
Good news is that wheat futures are up, past the $10 mark. Will be interesting to see prices after all the flooding in the midwest.
   / Pasture renovation project... #9
Excellent job. :D :D :D Nothing as pleasing as seeing your crop come up!:D :D :D
Now to get a proper type cultivator that is built for your tractor so you do not bend it up!:D :D :D And some different shovels for it for different jobs!
2014 TEXAS PRIDE GOOSENECK (A53843)
2014 TEXAS PRIDE...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2007 KUBOTA M9540 TRACTOR (A53843)
2007 KUBOTA M9540...
2018 John Deere 325G (A47477)
2018 John Deere...
