Spreader Pasture maint., manure management?
   / Pasture maint., manure management? #1
canoetrpr
Veteran Member
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
I'm quite new to this so I don't really have an idea of what implements would be necessary for pasture maintenance and manure management.
I have 16 acres of flat pasture. My Kubota L3400 and Woods 60" rotary cutter are on the way.
I have a fair amount of manure left over by the previous owners - in a pile - which I would like to spread over my pastures.
The pastures also have manure that was not collected, which I would like to collect and add to my manure pile to compost before I can spread it.
Anything else I should be doing to keep my pastures in good shape?
What implements do I need for pasture maintenance?
I am guessing I need a manure spreader. What would I use to collect manure from the pastures? Is a harrow of some sort required to break up a bit of the ground on the pasture from time to time - after I spread the manure for example for good areation.
Would appreciate your thoughts.
   / Pasture maint., manure management? #2
I would highly reccomend aerating the pastures. On all of our grazing land and hay meadows we pull a 15' Aerway across them once a year in the spring. Behind the Aerway we have a 15' harrow to spread out the manure a bit. We don't gather the manure before this, just scatter it w/ the harrow. BTW, we rent the Aerway and harrow for about $4/acre and pull it with our own tractor. This process has really helped build up our topsoil.
In your case, I think I would spread the pile then aerate/harrow.
Are the fields rough? If so, you might want to think about breaking them up with a set of discs or plows to level them before pulling a harrow and maybe a roller across them.
Also remember, these are fairly long processes. You won't see much improvement the 1st season. It will take time. Some of our fields we have been working on for 5 years or more. We do soil tests every 3 years to see where we are on nutrients. Soil tests, thats another thing you'll want to do depending on what you want to grow. Your local extension agent should be able to help with that.
my .02
   / Pasture maint., manure management? #3
not sure about how to deal with the pile of manure, but the pasture paddies can be dealt with by a pasture drag, especially if you plan to keep cattle on the land. A couple sheets of runway steel chained together and dragged accross the pasture will pulverize the dried manure and smear the otherwise wet ones. I made a drag out of nine tractor trailor tires by cutting holes from one side of tread to the other and chaining them together with a piece of 4" pipe at either end. It is heavy but crushes everything in its path and will last til the chains rust off.
swiftboot:
Sounds like a chain harrow would do what you have achieved with your setup. Do I understand this correctly?
hudr:
Thanks for those thoughts. How big a tractor do you have to pull that Aerway and the harrow?
I don't know for sure but I'm guessing that my 34hp machine won't be able to drag your setup. Renting sounds like they way to go though for a once a year job like this.
My pastures are in relatively good shape - bumpy in parts though. I'm guessing this is just from compacting by the horses that were here before - and maybe even grass growing over piles of manure :) (doubt the previous owner was good about breaking them up with a harrow).
I just plan to keep the pastures open as grass and am looking into putting a few head of highland cattle on them in the spring - some thing to keep this place looking like a farm :). Bit empty without livestock.
   / Pasture maint., manure management? #6
we have a 4320 JD (116hp) that pulls it OK in 3rd gear w/ duals on the rear. Our 5020JD (133hp) does an even better job. Of course, those aerways come in smaller sizes too.
If you just have a few bumpy spots I think a chain harrow would smooth those out after a while.
   / Pasture maint., manure management? #7
I use a 6' raer mower, a manure spreader, and a flexible tine harrow (www.wingfields.com) to manage my pastures. The tine harrow is very helpful to break up the manure turning them into fertilizer. I drag the tine harrow whenever any of the pastures have too many piles on them.
   / Pasture maint., manure management? #8
A disc and a section of chain link fence will work nicely for opening the surface and getting the goodies worked into the top soil.
OR, get the manure and create a nice big compost pile. You garden and your wife will love you for years to come.
   / Pasture maint., manure management? #9
Unless you plan to spen 24/7 picking up pasture pies.. I'd forget about collecting pasture maneuer, for composting then distribution. I use a heavy chain drag to bust up the maneuer in the pasture, and I dump my barn collections in a pile. I turn it now and then with my loader. If I had more animals, I would then pile into a maneuer spreader and spread periodically.. but I only have a few hay burners right now.
Soundguy
Ok soundguy - I feel pretty daft now!
I had always assumed that my manure pile came from the previous owners picking up the manure from the pasture.
Of course you've cleared it up for me that they never did this! With a high degree of probability my manure pile is constituted of manure that their horses left in the stalls.
I'm not a horse person at all - so y'all will have laugh at me for this. I kennel my dogs in the stalls from time to time for a few hours when we are out somewhere and since they don't poop in there - somehow the thought just had not occured to me that horses were not house trained!
I feel pretty silly now :)
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2012 TRANSCRAFT/WABASH 48X102 STEEL FLATBED (A55745)
2012...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2019 John Deere 8295R Tractor (A53485)
2019 John Deere...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
