Pasquali 993
   / Pasquali 993 #1
DavidNPro
South Central, PA
Kioti DK 45SE, 993 Pasquali
I finally got the Pasquali 993 out today and took some pictures.
Thinking of selling the old girl depending on what it is worth as it just sits in the corner of the garage these days. Thoughts???
   / Pasquali 993 #2
That's an interesting machine. It have a 3 point hitch? I've always thought those tractors would be good in the woods.
   / Pasquali 993 #3
NICE!:thumbsup:
I'm a proud 993 owner myself, use my Pasquali for all sorts of work where a conventional tractor can't fit. Use it for skidding logs, general bucket-work (although a full-float on the loader arms would be nice, still original 1971 Italian hydraulics with twin-sticks, no-float).
And in the winter, a 5 foot 2-stage PTO snowblower with 1/2-cab, & full LED lighting all around, (need dimmers for LED's, its like stadium lighting!)
Regards,
Shadow
   / Pasquali 993
Yep, the backhoe can be removed with about 6 bolts or so and it runs off of a self contained PTO hydraulic system. They are definitely very stable and perfect for small areas.
   / Pasquali 993
NICE!:thumbsup:
Yep mine still has the original front hydraulics for the loader with the twin stick controls. I added a PTO pump for the backhoe so it would be self contained and leave the tractor side of it alone. I did a ton of work when I first picked mine up. It has a new front ring gear and pinion, new bearings and PTO shaft in the rear. Not to mention numerous bearings and bushings in the transmission and around the "roll casting" area. At one point it was in two pieces and basically looked like a motor and explosion on the garage floor. My wife loved every minute of it and do not listen to her if she says otherwise. :laughing:
Definitely a unique machine that will do some serious work if treated right.
Pallet of Miscellaneous Heaters (A52384)
Pallet of...
2012 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2012 Ford F-450...
1999 Hypac C-766 66" Double Drum Vibratory Roller (A52384)
1999 Hypac C-766...
2014 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2014 DRAGON...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
2013 FREIGHTLINER CASCADIA SLEEPER (A53426)
2013 FREIGHTLINER...
