Parts or Replacement for NIMCO CV110 Mahindra 3015HST?
   / Parts or Replacement for NIMCO CV110 Mahindra 3015HST? #1
Midilink
I need to find a source for parts for this NIMCO controller CV110 10362-3S or a replacement. Having a difficult time finding a parts supplier which I've read here is not unusual.
I've seen links to THIS controller at Surplus Center Surplus Center - 2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
and am wondering if this is a direct replacement, (if the hoses connect in the same possitions).
This controller is used for my ML110 loader.
Thanks,
Dave
   / Parts or Replacement for NIMCO CV110 Mahindra 3015HST? #2
What is the pump GPM's on your tractor?
The valve you posted is a 10 GPM valve and has float and regen, and PB.
If the fittings and threads are the same, should work, and if not, add extensions to fit.
   / Parts or Replacement for NIMCO CV110 Mahindra 3015HST? #3
Midilink, did you find a replacement valve for your Mahindra? If not, I still have the Cross joystick valve off my 3215 with ML111 loader. Nothing wrong with it whatsoever-replaced it with a 3 spool valve for the grapple.
   / Parts or Replacement for NIMCO CV110 Mahindra 3015HST? #4
Can you share what you used for 3 spool valve? I have a 2815 and am looking to do the same thing on mine.
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
KJ 42'x30' Metal Storage Shed (A50121)
KJ 42'x30' Metal...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
