Parts breakdown for leak at injection pump on ford 1720
   / Parts breakdown for leak at injection pump on ford 1720 #1
jnhelton
new-holland 1720
Have a leak on left pipe outlet at the fuel injection pump. 99% sure its not the pipe connection but under the flange that pipe connects to. There's 3 oval oblong flanges that appear to be what each pipe fastens to. They each have a bolt at top and bottom. The bolts are 5 sided and would require some special wrench. Any chance just tightening the bolts will solve problem? Is there a o ring or gasket under each flange? Thanks
   / Parts breakdown for leak at injection pump on ford 1720 #2
I have the same problem what's the answer
   / Parts breakdown for leak at injection pump on ford 1720 #3
   / Parts breakdown for leak at injection pump on ford 1720 #4
There r 2 orings under each flange.. regardless of what ANYONE SAYS.. do not use any other orings but factory orings designed to go in that position..
Yes a special socket is required..
They are that way because it’s a safety and emission thing..
The flanges are “slotted” to set the equal delivery between cylinders and locked down w that bolt..
I rebuild them daily..and keep the parts in stock..
48" Pallet Forks  (A52384)
48" Pallet Forks...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52748)
Quick Attach Skid...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
