parts availability on 655 & 755
   / parts availability on 655 & 755 #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
Been looking for an extra mower for my lawn. I have been looking at 655's & 755's. How are these on parts availability. Do not need 4wd since will only be using it for mowing.Would consider a slightly rough one to restore back to new condition.
   / parts availability on 655 & 755 #2
I broke the bolt that holds the drive gear to the hydrostat motor (known issue) last year and had to tear into the tractor fairly deep as a result.
I replaced a lot of unrelated parts when I was in there and the only part I was not able to source from Deere was the steel hydraulic line that went from the hydraulic pump to the flow divider. Looks like the flow divider was changed at some point and the line also changed, so the supplied part was the wrong shape. In the end, I just used a piece of hydraulic hose.
Everything else I needed, was available which was a major surprise for me.
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Kinze 600 Grain Cart (A52349)
Kinze 600 Grain...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
