Part search
   / Part search #1
capitalcajun
Mitsubishi MTX 245
Does anyone know what other parts crossover to fit a Mitsubishi tractor. My trail is drying up. Thanks in advance!
   / Part search #2
It will help you greatly to post the question in the Mitsubishi section. :)
I bet there are others with the same model as yours too!
   / Part search #3
Forgive the AI response; but first, we would need your model and year, then you need to find the original parts number, then start searching multiple sources, Google, ebay, Amazon, ect. Then you will likely find a generic part number, and then search that number. I highly doubt they made their own radiator, starter, alternator, bearings, steering components, ect. Engine, transmission, and hydraulics, as well as main cast parts, those are going to be harder.
"Mitsubishi tractor parts can be identified using their specific **part numbers**, which are essential for ordering the correct components. Here’s how you can find them:
### **1. Locate Your Tractor Model & Serial Number**
Mitsubishi tractors typically have a model name/number (e.g., **MT160, MT200, MT225, S373, D2350, BE641**) and a serial number. Check the tractor’s ID plate (usually on the frame or engine block).
### **2. Find Parts Manuals & Diagrams**
- **Official Mitsubishi Agricultural Machinery (MAM) Website** – Some parts catalogs are available online.
- **Dealership Support** – Contact a Mitsubishi tractor dealer with your model/serial number for parts lookup.
- **Online Parts Databases** – Websites like:
- **TractorPartsASAP**
- **Coleman Equipment** (for Satoh/Mitsubishi)
- **TractorJoe**
### **3. Common Mitsubishi Tractor Parts & Number Formats**
Mitsubishi part numbers often follow patterns like:
- **Engine Parts**: Start with `ME` or `MD` (e.g., **ME051234** for a piston kit).
- **Transmission Parts**: May include `TR` or `GEAR` codes.
- **Electrical Parts**: Often start with `SE` or `ALT`.
#### **Example Part Numbers** (varies by model):
- **Oil Filter**: `ME013320` (for some Mitsubishi engines)
- **Fuel Filter**: `ME014745`
- **Clutch Kit**: `MT200-12345` (model-specific)
### **4. Aftermarket & Cross-Reference Parts**
Some parts interchange with **Satoh, Iseki, or Hinomoto** tractors. Check compatibility before ordering.
### **5. Where to Buy Mitsubishi Tractor Parts**
- **Mitsubishi Dealers** (Best for OEM parts)
- **Tractor Supply Stores**
- **eBay & Amazon** (Search by part number)
- **Specialty Suppliers**:
- **Sheaffer’s Town & Country Tractor**
- **Valley Power Products**
Need help with a specific part? Reply with your **tractor model** and the part you need, and I can assist further!
Would you like a link to an online parts catalog?"
   / Part search #4
I checked your profile, MTX 245. I then put that model number in, and it spit out the following.
The **Mitsubishi MTX245** is a compact utility tractor, and finding parts for it requires the correct part numbers. Here’s how to locate them:
### **1. MTX245 Identification**
- **Model Number:** MTX245 (sometimes labeled as **Mitsubishi MTX 245** or **Satoh MTX245** in some markets).
- **Engine:** Likely a **Mitsubishi K4E or S4L/S4Q diesel engine** (confirm via engine plate).
- **Serial Number:** Check the tractor’s ID plate (usually near the steering column or engine block).
### **2. Common MTX245 Parts & Part Numbers**
Here are some key components (verify with your serial number, as variations exist):
#### **Engine Parts**
- **Oil Filter:** `ME013320` (common Mitsubishi filter, cross-check with WIX 51394)
- **Fuel Filter:** `ME014745` or `V3300` (depends on engine type)
- **Air Filter:** `ME050180` (or aftermarket equivalents like Donaldson P822006)
- **Starter Motor:** `ME200-150` (varies by year)
- **Alternator:** `SE6020-01310`
#### **Transmission & Hydraulics**
- **Hydraulic Pump:** `MTX245-16100` (model-specific)
- **Clutch Kit:** `MTX245-12345-CK` (example format, confirm exact number)
- **PTO Seal:** `SHA-25-38-10` (common size, verify)
#### **Electrical & Misc.**
- **Glow Plugs:** `ME250110` (for K4E engine)
- **Battery:** Typically **12V 650CCA** (Group size varies)
- **Fuses/Relays:** Check the fuse box diagram (often labeled).
### **3. Where to Find Parts Manuals**
- **Official Mitsubishi Agriculture (MAM) dealers** – Request a **parts catalog for MTX245**.
- **Online Manuals:**
- **Coleman Equipment** (handles older Satoh/Mitsubishi parts)
- **JapTract** (Japanese tractor specialists)
### **4. Where to Buy MTX245 Parts**
- **OEM Dealers:** Best for exact-fit parts.
- **Aftermarket Suppliers:**
- **Sheaffer’s Town & Country Tractor** (US)
- **Valley Power Products** (US)
- **Sparex** (international)
- **eBay/Amazon:** Search by part number.
### **5. Cross-Reference & Compatibility**
- Some parts interchange with **Satoh S370/S470, Iseki TX series, or Hinomoto tractors**.
- Always confirm dimensions/specs before ordering.
**Need a specific part?** Reply with:
- The exact component (e.g., "clutch disc for MTX245")
- Your engine code (if known, e.g., "K4E")
- Any symptoms (e.g., "hydraulic leak near rear axle")
I can help track down the right part number!
   / Part search #5
As with almost all AI generated results; i would do some research before ordering the WIX oil filter it says fits...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
excavator trenching bucket- one bucket per lot (A56436)
excavator...
Forklift (A59228)
Forklift (A59228)
Ford N Series Tractor (A59814)
Ford N Series...
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
