part numbers
   / part numbers #1
heehaw
Veteran Member
russellville, arkansas
Kubota M4900, B7510 and RTV
i have a parts breakdown for the belly mower for my B6100; the belt from the pto clutch to the center mandrel is 70080-00271; and under remarks it says A117; can anyone cross reference that for a part number that i can use to get a belt at a local wholesale bearing/drivetrain/drive-belt dealer; they have lots better prices, and heavy duty belts; the belt thats on the mower deck is a 70080-00272; A-88; PLUS; according to this break down, this deck has no guide wheels on the rear; only an anti-scalp roller, 70080-00222; on the front; sure hope it mows ok when i get this all worked out; does reading about mowing decks make you feel any warmer...its @ 12degrees here...burrrrrrrrrr
heehaw
   / part numbers #2
heehaw,
you gave us the cross-reference yourself, you just may not have realized it. the A117 is a cross-reference that any shop should recognize ... as I recall, it breaks down to
A (style, as in v-shaped) 117 (length) An A-88 would be the same style, just shorter.
Standard v-belts are usually a (narrow, I believe) and B (wider).
Just make sure you buy a good quality one like Gates as they're usually not much fun to replace when you're in the midst of mowing.
Now - the $64 question ... what are you doing playing with a mower when most of us are wondering if there's an end to the white stuff?
pete
too bad that common sense ain't
   / part numbers
thanks, i wondered what the A88 was for..we have a company here called Motion Industries; they have heavy duty belts at much better prices than dealers..
the only attachments i have for the B6100 is a rear tiller, a flail mower and a belly mower....not much i can do with those attachments this time of the year..so i'm just tryin to get it ready..its so cold, i don't stay out much..break the ice on the pond..water the other critters and run back in..thanks for your help..
heehaw
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
John Deere 400 Rotary Hoe (A50514)
John Deere 400...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
International 1566 Tractor (A50514)
International 1566...
