Part numbers for NAA Caps
   / Part numbers for NAA Caps #1
skylarkguy
Platinum Member
Dallas Oregon
Mitsubishi MT372, Ford NAA
Does anyone have a good Napa part number for the radiator cap and fuel tank cap for an NAA? I also have Oriely's and car quest near by but my preference is Napa. Thanks.
   / Part numbers for NAA Caps #2
I don"t but I am Sure soundguy will know.
   / Part numbers for NAA Caps #3
the fuel cap is a weird deal. most places will list the diesel cap.. the old cap is non vented.. and there was a program to swap out for a vented cap.. but I believe it is over.
a TSC will have the diesel cap cheaper ( by far ) than the dealer...
part number D5NN9030A
you will find that many 'ear' style caps fit.
some tape the cap and trill a hole and put in a pop rivit that can jingle in it as a vent.. but not so much that fuel sloshes out.
radiator cap is, i believe a 7 psi cap part number 1T8100A2 an older 4 psi N cap will fit but not reccomended.. nor is a replacement 11-14 psi cap.
ps.. any cap gas or rad, from a 53-64 model 4 cyl will fit.. etc..
The fuel cap I have is non vented. It seals so tight that eventually the fuel stops flowing, so I was looking for a vented cap. I'll look for the diesel cap, or else plan to modify mine.
On the radiator i have the original one that was with the radiator. It is a 4 psi and tests good, but is kind of loose fitting. I'm very wary of radiator caps, after loosing a buick motor due to a failed cap, and (driving up to Lassen NP in over 100degree temps, with the bad cap)
Thanks SG
   / Part numbers for NAA Caps #5
yeah.. 4 will be fine..
Napa Part numbers:
Rad cap (7psi) BK 703-1460
gas cap (vented) BK 703-1220 (this is shiny chrome for those who are concerned with such things)
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
Ingersoll-Rand Winch (A53117)
Ingersoll-Rand...
2019 Kenworth T270 Rollback Wrecker (A53117)
2019 Kenworth T270...
