Part number for 3rd SCV kit open station 2003 JD4120
   / Part number for 3rd SCV kit open station 2003 JD4120 #1
803wideglide85
massey furgeson 240/john deere 790
I am a newbie to posting threads, but have learned much from reading them; so thanks in advance to the many kind and experienced equipment guys/gals for sharing.
I've been reading what I can to understand retrofitting the 3rd SCV for my 4120 loader; and now I'm pretty confused. People talk about using solenoid, electric switch kits (I know there are aftermarket available-in fact have one on my 4310) it has a button on the loader handle and I don't care for it's full on/off and rapid movement. It "breaks" into the circuit to lift the loader and was installed when I bought it, there is possibly a flow issue, but I digress.
My 4120 (unless I'm mistaken) already has a 3 valve control (with I believe a detent in one direction--in and outs are plugged), and a slot cut out in the three point lever cover. Is there a kit that contains the pre-shaped lines that parallel the existing loader lines up to the quick connect fitting,and the lever, and appropriate linkages?
I've searched the JD parts catalogue, found a number I THINK might be it, but description is vague , confusing. 'Not asking for folks to research numbers, rather, where should I be looking?
Why would a kit be different for a cab tractor? Am I wrong about the usage and installation of said kit, and wouldn't a lever control be better for sensitivity, "holding" (a grapple), and cleaner setup? I installed the OE power beyond kit and it was very simple to the kit number and put the circuit on. Incidentally; the 4310 came factory with what looks to be the same 3 circuit control valve; also the 3rd circuits just plugged. Thanks again
   / Part number for 3rd SCV kit open station 2003 JD4120 #2
If on your 4310 you have a diverter valve the button should only "divert" the valve to something else (your grapple?) and the lever should allow operation. I would divert the bucket dump/curl function rather than the boom lift/lower function. Maybe you do not have diverter valve, but a solenoid operated vale that is either on or off, so no flow control. I digress too.
For the 3rd function kit for your 4120 JD parts shows two kits with a serial number break. Later kit is a diverter. Hard lines go to the rear of the tractor not the middle where your loader hooks up. I do not see this as a problem, either install to rear and use hoses to get to the loader (then you have a rear set for other uses) or install and substitute hoses for the hard lines and run them where you want.
Difference between a cab and open station kit MIGHT be due to lever location or line routing.
I use a rear SCV on my 2030 for my grapple ( I ran hoses from the rear to the mid 3 function coupler. I can unhook at the rear if that SCV is needed at the rear) My valve has detents in both directions that "kickout" at full pressure. I normally just move the lever to the detent to open or close the grapple. I have not found the need for sensitivity with the grapple.
It sounds like you just need a lever and hoses to add 3rd function.
You might try posting this in the John Deere Owning Operating section for more replies.
2022 Club Car...
2014 New Holland C238 Tracked Skid Steer (A50860)
2014 New Holland...
Target Ecoline Walk behind concrete saw (A49461)
Target Ecoline...
2011 Ford Expedition XLT SUV (A48082)
2011 Ford...
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2002 WACKER RD25 ROLLER (A51222)
2002 WACKER RD25...
