Parking brake light on all the time????
   / Parking brake light on all the time???? #1
AutoUnionTypeC
Upstate N.Y.
CK20
Within the last couple of operating hours the parking brake light on my CK20 has stayed on even the brake lock was disengaged. I plan on giving my dealer a call in the AM but thought I'd throw it out here in the mean time.
One thing I had to do was tighten the bolt that the brake lock pivots on as it was loose and the lock lever was pretty sloppy. I had hoped to find some sort of micro switch that the lever engaged..... but no luck. Any insight gang?
   / Parking brake light on all the time???? #2
There has to be a switch somewhere in the linkage, but I've never looked. Sorry for the lack of help. /forums/images/graemlins/confused.gif
   / Parking brake light on all the time???? #3
My CK25 did the same thing. It turned out that the weight of the parking brake lever was just enough to apply pressure to the micro-switch to keep the light on. A little tweaking of the micro-switch trip strip did the trick. Not exactly sure where your switch is but if you look at the end of the lever under the dash you should be able to find it.
</font><font color="blue" class="small">( My CK25 did the same thing. It turned out that the weight of the parking brake lever was just enough to apply pressure to the micro-switch to keep the light on. A little tweaking of the micro-switch trip strip did the trick. Not exactly sure where your switch is but if you look at the end of the lever under the dash you should be able to find it. )</font>
My switch is in the same place as yours, I just didn't recognize it for what it was. /forums/images/graemlins/blush.gif The trip strip had gotten behind the plate meant to depress it so I couldn't see it. The pivot bolt being loose was the root cause, it must have allowed the lever to shuck just enough to allow the trip strip to get behind it. All is well now. Nice job with the "trip strip" thing, walking up from the garage all I could think of was…… "What in the @%!! am I going to call that thing?"……….I’d figured it out before I read your post, but I thank you kindly in any case.
Regards, Jamie
   / Parking brake light on all the time???? #5
Glad I could help. /forums/images/graemlins/smile.gif
2015 CATERPILLAR 303.5E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
16ft Trailer T/A Equipment Trailer (A50322)
16ft Trailer T/A...
2022 Polaris General 1000XP UTV (A50514)
2022 Polaris...
Feteral 8"x60' Transport Auger (A50774)
Feteral 8"x60'...
Electric Wheel Hyd. Dump Wagon (A50515)
Electric Wheel...
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
