Parker 721TC hose
   / Parker 721TC hose #1
powerscol
Veteran Member
SW Colorado
CT 235
My local Bobcat Dealer uses the Parker 721TC hose in making theirs - including the fittings. They have made up a couple to replace hoses on some of my hay equipment. They are very reasonable and they look well made. I know nothing about this hose and cant seem to find specifications to actually what it is. Parker says it exceeds 100R16 for what that's worth.
I got my mounting plate fabricated for my 3rd function and I think I can get a clean bend on a hose to the T port, if it will bend tight enough.
Before I go to them with the sizing I just need to know if this Parker hose is good enough for my 3rd function or should I go with 100R16 from several online sources?
Thanks Folks
   / Parker 721TC hose #2
It is a pretty tough hose, if I understand it right is a 100r12 4 wire hose and should be able to handle higher pressure than the 100r16 2 wire hose but may not be as flexible in tighter applications. The tc stands for tough cover and has a heavier cover than the std 721 hose. Parker 471tc is what our dealer mostly sells.
20" Sea Container (A47384)
20" Sea Container...
2005 Nissan Titan (A50121)
2005 Nissan Titan...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A50322)
2007 Godwin Pumps...
2023 John Deere Z994R (A50121)
2023 John Deere...
PT Canal Pump (A50121)
378752 (A51573)
378752 (A51573)
