Park yer backhoe dosedo
   / Park yer backhoe dosedo #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
I have been parking my New Holland 757C backhoe on 2 wood appliance dollies. Unfortunately the small casters have made it all but impossible for me to move the backhoe within my pole barn.
My remedy was a new project for a welded steel dolly with large steel ball bearing casters. It works and it works well! To see the dolly click here /forums/images/graemlins/grin.gif
   / Park yer backhoe dosedo #2
Looks pretty darn good. Do you set out the outriggers to remove the backhoe and then lift them up after the 'hoe is off the tractor? I need to set out my outrggers to remove the 'hoe. Lifting the outriggers after dismounting the 'hoe would save a lot of floor space for me. Building up the dolly to hold the backhoe stable, without using the outriggers, is a great idea.
Either way, that looks like how I could dismount my 'hoe. Set out the outriggers, dismount the 'hoe, drop on the dolly, lift the out riggers, disconnect the hydraulics and wheel it away.
Thanks,
   / Park yer backhoe dosedo #3
Looks great Mike, if I had the welder I'd be looking at something similar.
Have you (or anyone else) tried storing the hoe with the boom swung to one side. I know this is how they are shipped to take up less space but I haven't figured out how to do it in my garage /forums/images/graemlins/smile.gif
Dave to remove the backhoe from the tractor I set both stabilizers down and lower the boom on the floor to slightly raise the backhoe. I then pull the front pins on the sub-frame mount for the 757C backhoe, yank the top link off and slowly pull forward away from the backhoe. Once I am just clear of the backhoe I idle the tractor down, set the parking brake, and place it in neutral. I then wheel the dolly under the backhoe and slowly lower the BH onto the dolly. The welded stops that I added to the dolly always place the backhoe in the same position time after time. I then raise and lock the BH boom, and raise the stabilizers. I have always used a short length of nylon rope to tie the stabilizers together least they will start to sag when the BH is stored. I also use one adjustable strap to lock the BH to the dolly. I then stop the engine and move all the BH controls to equalize the hydraulic pressure and disconnect the BH hydraulic lines. The dolly/backhoe can now easily be backed away from the tractor.
To install the BH on the tractor I park the tractor in the pole barn, raise the 3-point hitch, set the parking brake, and kill the engine. I then maneuver the backhoe/dolly as close to the tractor as needed and connect the backhoe hydraulic lines. I remove the rope that I use to tie the stabilizers together and remove the adjustable strap that ties the BH to the dolly. I then fire up the tractor, slightly raise the boom so that the boom lock can be removed, and lower the stabilizers in conjunction with the boom to lift and stabilize the BH while raising it off the dolly. I then slide the dolly out the rear of the backhoe and continue to mate the BH to the tractor in a normal fashion.
RobS when I first got my BH I tried setting the boom to the side once when I parked the backhoe but it seemed very unstable in that position. Plus once the boom is off to the side it can no longer be used to raise or lower the BH in a balanced position which is necessary for the docking procedure to the tractor. The boom more or less wants to flip the BH on its side when raising or lowering the BH which isn't good. I would not recommend parking your BH with the boom to either side.
   / Park yer backhoe dosedo #5
Real nice job. It looks like it would work very well. Maybe you could just roll the BH right to the job and skip the tractor hookup (except the hydraulics) all together?? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
John the backhoe moves so easy on the dolly that I'm thinking about putting a leash on it and walking it around the block along with my dog. /forums/images/graemlins/cool.gif
On second thought I don't need the extra exercise that bad.
P.S. In case I didn't say it earlier John, thanks so much for helping me out with this project. Your cutting and drilling of the steel afforded me a position that I could spend my time assembling, welding, and painting. It all went a lot smoother and quicker with your help!
   / Park yer backhoe dosedo #7
Mike,
Great job.
Another satisfied Summit Equipment customer I see. /forums/images/graemlins/smile.gif I picked up the steel for my dump wagon bed there - interesting place and the folks seem pretty nice.
One thing you might to consider adding is something to catch or secure the bucket - if it's anything like mine it will have a tendency to uncurl over time. Since I don't have the subframe to contend with I built mine so that the bucket is the second point that the 'hoe rests on - although now with incorporating the steel casters like you used I'm going to have to redo the whole thing since the bolt pattern won't line up with the old casters I had on it.
   / Park yer backhoe dosedo #8
You wouldn't happen to have a drawing of that, would you? We have the same equipment and it sure would be helpful for me to build one. Right now my 'hoe sits and blocks a big portion of my shop... /forums/images/graemlins/frown.gif A 'hoe sure is a nice piece of equipment when it is on the CUT and working, but it makes a darn good boat anchor when not in use.
Doug
Summit Equipment is one of my favorite places to shop. I learned a long time ago to carry a flashlight with you whenever you shop there as its always a dark building inside and always be sure to dress warmly in the winter as they don't heat the steel storage area. Brrrrrr. Oh, work gloves are always a plus when handling ice cold steel too.
Doug I actually loaded AutoCAD 2002 into my computer to lay out the dolly. Unfortunately I have never used a CAD program before and figuring it out was taking me more time and effort than putting a pencil to paper.
So I ended up with a lot of scribbling on a piece of paper. PM me your email address and I'l redraw it and fire it back to you. However please don't take off points for my drawing skills. /forums/images/graemlins/tongue.gif
Electric Mobility Scooter (A51694)
Electric Mobility...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2008 Chevrolet Malibu Passenger Car (A51694)
2008 Chevrolet...
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
