Bob_Young
Veteran Member
- Joined
- Jul 5, 2002
- Messages
- 1,244
- Location
- North of the Fingerlakes - NY
- Tractor
- Ford 4000; Ford 2000(both 3cyl.);JD40; 2004 Kubota L4300; 2006 Kubota B7610; new 2007 Kubota MX5000
I see TC is pushing it's non sleeved (Parent Bore) engines as an improvement over sleeved engines. They identify "improved rigidity" as a feature. Of course virtually every iron block automobile gas engine made is non-sleeved so this isn't exactly earth shaking technology even if it does have advantages.
My impression was always that the sleeved engines were superior because they could be rebuilt an indefinite number of times; even after substantial cylinder damage. Non-sleeved engines, on the other hand, could only rebuilt until cylinder wall thickness was reduced (through wear or machining) to some minimum value. Debris (such as a valve head) bouncing on top of a piston can quickly reduce a non-sleeved block to junk while a sleeved block may only require a new cylinder sleeve.
So, TBN engine gurus, what's the verdict? Does the sleeved engine truly have better rebuild qualities? Since few Compact tractors will be rebuilt more than once, does it really matter if sleeves are better? (No point in paying for an advantage that might never be needed.) Are there advantages to the "Parent Bore" engines (such as lower cost, more easily maintained tolerances, rigidity) that make them better choices for the compact market?
To my knowledge, all compact tractors currently have non-sleeved engines (unless Perkins powered) while larger Ag tractors and most old Ag tractors of any size were sleeved (except Fords).
Just a rainy day question.
Bob
Bob
