The Honda "i" series of generators are different than others, they use an electronic inverter to produce AC power. They are pre-designed to allow connecting two units in parallel to double the power output. I believe the cable is nothing special, except the connectors may not be readily available elsewhere. I had a Honda 1000i that I used where I needed a very quiet generator (condo). The inverter allows the engine to automatically modulate speed in proportion to load demand, without affecting the voltage or frequency. Mine worked great and was amazingly quiet, compact, and fuel efficient. The only downside, besides cost, was the limited wattage and 120 volts only.
