Pallet forks
/ Pallet forks #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Need some forks.Any good recommendations for clamp on forks will help.I see them priced from about$89.00 to over $450.00 for clamp on's.A 1000# limit is fine but I don't want poor quality.What are you guys using?.Also looked at QA forks,would be nice but pricey. Thanks for the info.
Found these on the web anyone have em?
http://www.ctiattachments.com/overview_clampon.htm#clampon_advice or these
http://www.paynesforks.com/light.htm and these
http://www.edneyco.com/catalog/product_info.php?products_id=916
/ Pallet forks #2
Do you have welding skills?
If so you can build your own in one afternoon for less than $50. I offer free plans to anyone who wants them. Just PM me with your real email address. I have built 6 sets myself and have given out plans to over 250 TBNers. A complete thread describing construction can be found by doing a search here.
/ Pallet forks #3
I had a 3 point carry-all sitting around and welded a pair of "wings" onto it that allow me to pick it up with my QA FEL. Works pretty well, but is not width adjustable. I made the lift points from some 3" channel steel I had. I set the angled plates at 45 degrees from the vertical. I cut the hole in the bottom one for the lock pin by first scoring the lines with a circular saw, then turning my welder up to about 300 amps and blowing through it along the shallow cuts using a small diameter rod. It ain't pretty, but it worked very well.
2008 Chevy Trail Blazer (A62679)
2008 Chevy Trail...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A65643)
1994 SHOP MADE...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
