Loader Pallet Forks
   / Pallet Forks #1
Engine Mike
Rochester hills michigan
Kubota B2320
I have a 5 year old B 2320 with fixed pin bucket attachment. I am looking for pallet forks but all seem to require investment in a quick connect. Is anyone aware of pallet forks that utilize fixed pins for attachment?
   / Pallet Forks #2
There are forks available for fixed pin attachment but if you can't find any,they are simple to fabricate.
   / Pallet Forks #3
Depending on what you need to lift, you could go the route of the kind that clamp to the bucket.
   / Pallet Forks #6
Check out the load capacity first. I found when I was shopping around the Kubota's seemed a bit light on FEL capacity. You will have less then 1000lbs at the pins and likely an effective working load capacity of under 500 lbs using pallets.
I love the forks, and they are necessary for the way I store and handle firewood (on pallets). But even with the larger machine I have, I added RimGuard and use 900 lbs of ballast on the 3 PH.
When I had my JD855, I used a carry all on the 3PH to move pallets as it had a lot more capacity than the FEL. For occasional use that may be worth considering as switching over pin FEL attachments will get old quick even if you are handling light pallet loads.
   / Pallet Forks #7
Do you have any idea the supplier that may sell fixed pin forks?
Since there is so many different pin configurations from various manufacturers, there is really no money to be made making them.
   / Pallet Forks #8
I taking a different approach. Not sure it will work for others, but it will do what I need. I've got a thread started here somewhere, but I don't have too many pictures yet because I don't have the details worked out. I'm using a Carry All rigged to strap/chain into the FEL bucket that will slide into a standard pallet to lift firewood. I don't have any scales or other means of testing load capacity.
   / Pallet Forks #9
   / Pallet Forks #10
I have a set of fixed pin forks that I would like to sell, but they are from a medium size Ford TLB, and would likely not fit your machine.
UNUSED FUTURE MINI EXCAVATOR HEDGE CUTTER (A51244)
UNUSED FUTURE MINI...
2015 Peterbilt Garbage Truck (A50323)
2015 Peterbilt...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
1975 Chevy C60 Grain Truck (A50514)
1975 Chevy C60...
UNUSED FUTURE QUICK ATTACH PLATE GRABBER (A51244)
UNUSED FUTURE...
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
