Painting a steel roof
   / Painting a steel roof #1
marty
Bronze Member
Mid West
Boomer 33D
I have a older portion of a barn that has galv. roof on which has a little rust and pulling up on the bottom sides. Has anyone found a good paint that can be used on old galv. roofs?
Thanks in adance,
Marty
   / Painting a steel roof #2
Marty,
Before trying to paint I would try to stop the rust. A product that's good for stopping progression of rust is os-pho. My spelling might not be correct, but it's a pale-green liquid with about the consistency of water. I've bought it at Ace hardware in the past and they also have a "house brand" that's the same chemical. Follow the directions and it will provide a good base for painting.
I've seen primer marketed for use on galvanized metal that might work. Never used it.
I have used "kool-seal" and similar products designed to cover mobile home roofs with satisfactory results, but never on a galvanized roof. They seem to have an asphalt or tar base with fibers mixed in and dry to a silvery color. Generally sold in five-gallon cans. Hope this helps.
   / Painting a steel roof #3
Tractor Supply co. has some zinc primer for rusty sheet metal. I have not tried it yet but have the same problem as you and intend to use it this summer and topcoat with Aluminium paint.
   / Painting a steel roof #4
I painted my pole barn roof with Rustoleum last summer. I had some rust spots on the ridges but the paint covered it very well and so far it looks real good.
   / Painting a steel roof #5
galvanized will have to be primed with the corect primer or the paint will flake. I also think there is something you have to wash it with first.
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
