Painting a fence
   / Painting a fence #1
Ghost River Retrievers
Bronze Member
Benton County, MS
New Holland
I hate to paint, but have about 600' of 3-rail fence that has to be painted. And to make matters worse, I'm going from white to black, so will probably have to paint it twice.
So my question is what is easier/faster (I'm not sure those are the same...I'd prefer faster over easier):
•brush
•power roller
•sprayer
I'll appreciate the advice provided, it's always good on TBN, since it's based on experience.
Thanks!
   / Painting a fence #3
Rent an airless sprayer and make it happen. Pressure wash first though.
   / Painting a fence
Thanks for the advice.
It sounds like spraying, by me or somebody else, is the way to go.
I'll take a look at FenceCoat!
GRR
   / Painting a fence #5
You just need to convince your buddy that painting the fence is fun and sucker them into doing it.:laughing:
   / Painting a fence #7
What condition is the existing fence and paint? What type of paint was used on the fence before? How often do you want to do this again in the future? As much as you don't want to do it now, doing it again in five years is going to be even worse if you do not do all the needed prep work first.
I'm not a fan of pressure washing anything wood before painting it. This Old House TV show on PBS had an episode where they pressure washed the siding on a wood house and then came back a month later and found that the wood was still wet inside, between each other. It wasn't 100%, but there was enough moisture that the painting guy said there was no way he could paint the house with it like that.
I'm a huge fan of using high quality primer before painting. If you have bad spots, use something designed for exterior wood. Sherwin Williams is my go to store for anything that will need special attention.
Spraying is probably the easiest way to do this, but you will have realize that a lot of the paint will just go off into the air. Another problem with spraying is that you will miss spots if the fence had irregular angles, or a rough surface. In my experience, I will spray, then go back over it with a brush or roller, depending on the job and what I'm spraying. I've also found that sometimes a brush is the fastest way to get it done, even though it might not seem that way. I factor in half an hour of cleaning the sprayer before deciding to use it when debating on what to use.
   / Painting a fence
The wood is in good shape; I bought the place a couple years ago and have no idea what paint the previous owner used.
Pressure washing will he tough because water source is 1/4 mile from the fence.
2016 Ford F-250 Service Truck (A44571)
2016 Ford F-250...
1010 (A44391)
1010 (A44391)
2021 John Deere 5055E Tractor (A44391)
2021 John Deere...
2008 ADVANCE ENGINEERED PRODUCTS PNEUMATIC TRAILER (A45333)
2008 ADVANCE...
7x11'9 Portable Office Container (A42021)
7x11'9 Portable...
More info coming soon! (A42742)
More info coming...
