Pad or no Pad
   / Pad or no Pad #1
Silver_Knight
Marble Falls, TX
I have two quotes for a slab for my new 50x86 barn. The first quote of 25,500 is for a pad that will be 5 foot larger than the slab plus the slab. The second quote is the slab only for 20K. These quotes are from the same guy. My question is what is the advantage of having the pad built? The back side of the slab will be 30" high by going without a pad.
   / Pad or no Pad #2
Pad material should cost less than concrete.
The pad also provides a compacted area that hopefully has natural drainage.
Egon
   / Pad or no Pad #3
The big difference is going to be drainage. If there will be water running alongside the slab there is a chance that it will erode and eventually run under the slab. Building up the pad around it will help avoid that situation. Depending on your drainage you might not have a problem without one though.
One person mentioned a nice thing about not having a pad was putting a door on the part of the barn that is 30" high and using that as a natural loading dock.
I built my own pad site up this weekend for my 30x40 barn. It ended up costing $800 and about 20 hours of work. ($500 of fill dirt, $100 rental of a jumping jack and $200 labor for the kid to run the jumping jack) I had received a quote to do it for $1,200. In retrospect I should have just hired it done, but at least I got some experience using the tractor and felt like I accomplished something. I know I packed it in good and solid with 4 separate layers with packing each layer down good.
I only built my pad about 1 foot extra and then it slopes down at about a 20 degree angle for another 8 feet or so at the tallest spots. This takes care of any erosion problems but it doesn't leave a very nice work area around the building if you need to work on it.
That's my 2 cents worth.
Nathan
   / Pad or no Pad
I also thought it would be cheaper to build up with a pad but from the price difference I guess I will go with a slab on grade. The 30 high slab in the rear will not effect anything since there are no doors on that side. Drainage also does not appear to be an issue.
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2007 International 4300 Dump Truck (A51692)
2007 International...
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
2000 International 4700 26FT Box Truck (A51692)
2000 International...
Adams 6T Fertilizer Spreader (A53473)
Adams 6T...
Towable Diesel Tank (A53421)
Towable Diesel...
