Pace loader valve?
   / Pace loader valve? #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
I have a koyker loader with a Pace joy stick. It has always been a bit sticky but lately it has gotten difficult to use. It is the same with the tractor running or not. Is the an adjustment on the tightness? any help appreciated.
   / Pace loader valve? #2
The stickiness is due to non use.
Shoot some penetrating oil on the spools shafts.
You could take the valve apart, clean good, lube and reassemble.
You might check the mounting bolts. To much torque o the bolts may warp the valve body and cause binding.
If it is cable operated, check them also.
Check gimbels that push the spools for correct operation.
JJ, first of all thanks for the reply! I use this tractor 3 to 4 times a week. I have also tried the penetrating oil with no luck. It is not cable operated, seems like the binding may be on the Ball of the various shafts but since I am unable to find a part manual or anything else on this valve I'm hesitant to take it apart.
Again thanks for the help.
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
Honda EM3800SX Portable Gasoline Generator (A55851)
Honda EM3800SX...
2012 International 4300 Reefer Truck (A57024)
2012 International...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
