P&T Lamps on 4035
   / P&T Lamps on 4035 #1
tjus77
Bronze Member
Montgomery, TX
Mahindra 4035
I had taken the bulbs out of the clear forward facing lights on the ROPS because it was hard to see behind me in the dark. I decided to go back and put the bulbs back in and add a switch on each light. One side worked perfectly, the other side did not. I didn't put the bulb back in until after I wired the switch, but even if I by-pass the switch, I get nothing. All other lights work fine including the yellow bulbs.
My question is, does anyone know if there is an inline fuse in that harness, before I take it out of the ROPS to inspect it? The wiring diagram in the manual does not show one. I've checked all other fuses.
   / P&T Lamps on 4035 #2
Swap bulbs?
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
Whiteman 6' Ride On Concrete Trowel (A47384)
Whiteman 6' Ride...
2011 Bobcat S630 Skidloader (RIDE AND DRIVE) (A50774)
2011 Bobcat S630...
Woods F21D Zero Turn Mower (A50514)
Woods F21D Zero...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
