Richard
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 4,984
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We've got a dog run outside. Used welded wire and T-Posts. For the current "door" we just overlap the welded wire and use some hooks to close it.
We did this maybe 10 years ago and this part is starting to deform a bit. Having a Pyrenese jumping around in there might be a small reason for that. She's figured out that she can shimmy under the fence a bit because it flexes more than it should.
Enter idea for a genuine door. I'm thinking, drop maybe two 6x6 posts and use one for the hinge side and the other for the latch side. I've got a backhoe so digging hole isn't an issue.
Got to thinking.... just dig hole, drop post in and backfill? How about concrete? (light goes off and this is what I'm really asking about)
What if I dig hole, take a 5-gallon bucket, fill it with concrete. Affix to it one of those "receivers" that the post would fit in and bury that. Now, I have an anchor that will hold the post, if the post ever needs replaced, I'm not digging/chipping it out of concrete. I can just detach it from the receiver, slap another in and I'm back in business.
If I/someone ever wants to remove all of this, then again, remove post.... dig down a bit, grab bucket/remove and no traces of anything after you fill it back up with dirt.
It's possible (ahem) that I over-think things at times....
Thoughts on using a bucket under the post with (I have no idea what they're called) a "post holder" mounted to bucket to hold post? (this would be 2-3 feet underground so the ground would help hold things).
