DieselBound
Elite Member
Was mowing some brush today (with the NX5510) and looked back to see the PTO shaft had dropped from the rear of the tractor
Yoke was still on the output, with one U-joint cap in it. The one cap is chewed up a bit, likely from when the shaft decoupled. The yoke is hammered and likely needs replacing.
I had just had this replaced (by a NAPA shop). I don't trust the U-joint that they used. And now it looks like I need to replace the entire tractor side half of the shaft (w/yoke). I'm looking for input to make things right again.
Some background:
Acquired this bush hog -Bush Hog 286- earlier this year (or late last year). The previous owner said that he had to replace the shaft because he couldn't find a proper replacement U-joint. When I started checking things out after I got the unit I noticed that the U-joint's caps appeared a bit cracked/broken. Oh, this is on the tractor end of the shaft. I took this in to my local NAPA shop and had them replace the U-joint. And now with perhaps 10 hours of total use the U-joint gave way.
I was aggressively going after brush when it failed. I had been lifting up the tail wheel up quite a bit (hydraulic top link). I'd suspect that this overstressed the U-joint, but given that the unit came to me with stressed U-joints (I don't believe that the previous owner had a hydraulic top link on his tractor) I'm wondering if there's some other root problem going on here.
Some background:
