Oversized oil filter for 1540
   / Oversized oil filter for 1540 #1
DarkBlack
Elite Member
Central NH
Massey
I've switched to a PL14670 crankcase oil filter on my mf1540.
Its about double the size of stock, and for less money. I figured I'd run it at least a year before posting. I can say it performs perfect. The anti drain back seems to work even better than the stock size as the oil light goes out quicker at startup.
This should also fit the 1533. Only 'drawback ' is you need about 3 minutes more to temporarily remove the 'bolt' that the hood side panel clips on to, to screw it on(sits in front of filter). Totally worth 3 minutes in my opinion for better filtration. Expect to have to add a bit more oil at a change because of the increased filter volume.
   / Oversized oil filter for 1540 #2
That is what I did on my MF 1440. For about 10 years, I have been using a Motorcraft FL910. It wouldn't have bothered me to have went even larger but the turbo engine has it's oil cooler under the filter.
Skidloader Bucket W/Hydraulic Attachment (A50774)
Skidloader Bucket...
2006 Isuzu NPR 16FT Box Truck (A50323)
2006 Isuzu NPR...
2006 Ford F-550 4x4 Flatbed Truck (A50323)
2006 Ford F-550...
2019 JGL 2632ES 26FT Scissor Lift (A50322)
2019 JGL 2632ES...
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2020 International MV607 2,000 Gallon Water Truck (A50323)
2020 International...
