Overseeder
   / Overseeder #1
tarious
Bronze Member
Grand Forks, ND
JD 3320
Have any of you ever used an overseeder? I was looking at them online and it seems you can airate the ground and plant seeds at the same time. Apparently, all without having to pack or rake the ground afterwards.
If the manufacturer claims are accurate, it would be the perfect tool to keep a yard looking thick and dense.
   / Overseeder #2
Do you have a picture or link to the one you are referring to here?
   / Overseeder #3
Hello Northern Neighbor!
The good news is that the concept is great, the bad news is that unless you have real loose soil anyway, the ones I'm thinking you're looking at [Campbell Supply in SF had one that looked identical to the consumer grade ones I seen online] fall short in several areas as a combination machine.
The tines are flimsy and spaced too far apart to get a thick fill without several passes anyway. The commerciall ones have a rather smaller diameter, and tight spacing; a few tine style, but more often like a field disk minaturized [of course this very tight spacing is more for new than overseeding]. Also the drop type spreaders like built on the unit at Campbells aren't noted for very even seeding [not my largerst concern].
On the other hand the tines are too small far much aeration benefit.
I got a "heavy duty" [compared to Menards and Runnnings] lawn tractor spiker from TSC (Rugid, Red Devil, and Precision, are all the same, just regional labels it seems) for $125. Not exactly heavy duty in my mind, but it got into the tight areas I needed it for [I also had to redrill the lift bar, so I go more range from my wheels; they hit when the ground when the tines were pretty shallow {though great for seeding}]. I ran a pass [more in places] with some pretty good weight [perhaps 150lb]; then seeded [you can use a broadcast, or even a drop spreader, or whatever you get the best results from]; then I went over everything crosswise. For setting the seed [not even required if you get a good result during aeration]; I tried some without any weight, but thought about 50 to 100lb was about right; you'll need to play with your own soil and moisture conditions.
Not a perfect solution, but for a "combination" machine I think you'd be happier. If you really need aeration bad, a plugger [or maybe a wide toothed drum aerator] will make the spiker look like a garden rake. /forums/images/graemlins/tongue.gif
Good Luck! /forums/images/graemlins/cool.gif
   / Overseeder #4
Good thinking beenthere!
A link would be much more helpful than my wild guess. /forums/images/graemlins/smile.gif
   / Overseeder #5
I think you want a Ferguson Seeder. Ken Sweet sells them. See one of his ads here on TBN. I believe Indydirtfarmer has one of these, you may want to check with him to see if it fullfills all his dreams and aspirations, or at least works as it is claimed to work.
   / Overseeder #6
Your 'guess' is what I was 'guessing' too. And I think I have one of the 'spikers' like you mention that has a drop bin overhead that I can put seed in, and I have used it to 'overseed' old and new lawn. It gets the seed down, but the spikes make a 'slice' pattern roughly every 6" by 6", which isn't enough to either aerate or get seed worked into the ground. A dozen passes may do the job better, but a bit too time consuming, IMO.
I've used one with the drum fitted with rods, and it worked if the ground wasn't too wet, causing it to load up with mud and rendering it useless until the mud was cleaned off.
I think there is a good market for an invention to 'overseed' that hasn't been met yet.
   / Overseeder #7
I've used the Ferguson Yardmaker to re-seed a couple lawns, a horse pasture, and several thousand square feet of "grass filter strip". From what I can tell, it did a good job. All of the seeding has been done recently, and is just beginning to germinate. I'll be watching with great interest as to how the grass does. I plan on getting through the fall seeding season, then posting with further comments.
The drum (roller) can be filled with water to gain weight if needed.
The seeder itself is a drop seeder. They aren't the most accurate method, but on a 2-1/2 acre lawn seeding, I came with-in 3 pounds of the "target" amount.
Another 3-point overseeder I'd recommend is the Woods "Super Turf Renovator". (More than double the cost of the Ferguson unit though)
One feature of the Ferguson I realy like is the fact You can use it to seed, fertilize, spread lime, as well as aerify. Not "just" a seeder.
   / Overseeder #9
That seedavator looks way too cool! But [aside from the tight areas I was doing this spring] I can think of way too many areas I have that are screaming for that Yardmaker [I better wait till Indy's report this fall though! /forums/images/graemlins/wink.gif]
   / Overseeder #10
</font><font color="blue" class="small">( What about the Seeda-vator? )</font>
I demo-ed one (at work.... a golf course) last summer. That's a fine piece of equipment, for sure. The only doen side(s) are the price, and the large # of moving parts..... Lots to go wrong. Lots to maintain.
Because I am myself, I like simple........ /forums/images/graemlins/crazy.gif
1998 Genie Z-45/22 Boom Lift (A52384)
1998 Genie Z-45/22...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
43029 (A51691)
43029 (A51691)
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
